Audio outputs to right main only
Discussion in 'AV Receivers & Amplifiers' started by Bangkok_Ron, Jul 1, 2004.
  1. Bangkok_Ron
    Bangkok_Ron
    I have got a wierd one.
    To listen to Cable TV I am outputting the sound from TV to my Yamaha RXV 1400 via the TV out jacks. For some reason the sound will output only to the right main. Sometimes it starts OK and I can listen in surround for stereo or center for mono programs but it always swtiches at some point to right main. Once it's in that mode nothing short of turning the TV off will get it back to normal (even that doesn't work all the time)
    Any ideas on if its the TV or the AMP. DVD and radio is fine on the AMP and the using the TV speakers I get cable TV sound from both left and right but can't tell it's in stereo (Sony Wega 57" rear projection).
  2. lostprophet
    lostprophet
    May 11, 2003
    288
    Not the light side....
    +12
    are you able to connect to the amp direct from the cable box?
  3. MattTheBeanster
    MattTheBeanster
    Oct 23, 2003
    1,457
    Cornwall
    +116
    Try using a diff. set of inputs on the amp, if that doesn't work try using another cable. if it's neither of these them it'll be the cable box.
  4. MattTheBeanster
    MattTheBeanster
    Oct 23, 2003
    1,457
    Cornwall
    +116
    oops missed a stage, check the connection between the cable box and tv.
    basically work your way down the line.
  5. Bangkok_Ron
    Bangkok_Ron
    Boy do I feel stupid.
    Turned out to be the cables from the TV to the receiver. Believe it or not I have never had an RCA audio cable fail before. Guess it had a poor connection because i jiggled it around and it started working fine. Of course I replaced it once the problem was solved.
    I'm not used to it being something simple. Usually it's the opposite.
