Audio output on Panasonic TX-P50VT65
Discussion in 'Panasonic TVs Forum' started by oirishkev, Aug 10, 2013.
  1. oirishkev
    oirishkev
    Nov 30, 2011
    Good afternoon all,
    I am just setting up my new panel and struggling to find the audio output setting? I am going from HDMI on my appletv and I want to output it to my Amp via optical out. Its working at the minute but not in Dolby Digital?
    Aslo I cannot get the TV to pump its noises out over SPDIF. I simply cannot find the menu option in the tv sound settings. Please help?
  2. Rebel154
    Rebel154
    Sep 27, 2004
    527
    Doncaster
    +19
    I'm in the same position. I have just installed my new VT65 and also cannot find the menu entry for SPDIF Selection under the Sound Menu ( as stated in the eHelp manual on page 136).
  3. redaprilia
    redaprilia
    Feb 10, 2010
    931
    43
    +120
    I would have thought that the cables would be better this way :
    hdmi from apple box direct to the amp
    hdmi from "hdmi2" (arc) on the tv to the amp
    Enable the amp or the tv speaker in viera tools .
    no need to mess around with old optical cables
