Audio Output from Sony KD32DX40
Discussion in 'General TV Discussions Forum' started by wyerd, Dec 18, 2002.
  1. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    Upstate New York. USA
    +27
    I've plugged the audio output into my amp as I wanted to use the Dolby Prologic System from my Hifi rather than the virtual from the TV speakers. I set the TV speakers to off as described in the manual, but every time I put the TV into standby of turn off, the option is then reset back to default. Sony says that this is a "Feature"!! I see it as a bug with the software. Has anyone else come across this problem?
  2. perrdl
    perrdl
    Jul 29, 2002
    371
    19
    Worcester
    I'm not 100% sure, but I think that there is a button on the back of the TV near the speaker outputs. This can be used to turn the speakers off.
  3. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    Can't see anything. Nothing in the manual either. I'm sure it's a bug as the manual states :-
    "Highlight 'Reset' and press OK only if you wish to return the sound settings to their factory preset levels."
  4. perrdl
    perrdl
    Jul 29, 2002
    371
    19
    Worcester
    I am pretty sure that my father has the same TV, and there was a small round button on the back right next to the speaker outputs.
    I will have a look when i next pay him a visit.
  5. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    Great. Thanks.
  6. w3dal
    w3dal
    Aug 4, 2002
    5,058
    Chelmsford, Essex
    +590
    Hi.
    I have an FX66 TV and its the same.
    You turn the TV speakers off in the menu so you can use your AMP for sound and then when you put the Tv in standby or power on/off it resets and the Tv speakers are kicked back in.
    Its not to much of a pain for me as i have my DVD player and Digi box connected to my Amp, but for someone that does not it would be a pain!!!
    Dal :rolleyes:
  7. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    Doesn't make any sense having the option available at all then!!!
    It makes me mad when you pay hundreds of pounds for a TV and you end up with stupid niggley things like this!!!:mad:
  8. garywork
    garywork
    Just seen a 32DX40 in a local dealer - intrigued by the free
    dig channel bit
    also
    does your TV have 2 wires holding up a shadow mask
    on the CRT ?
    THANKS
  9. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    Shadow mask???
    The picture quality from FreeView i've found is better than Sky..... I do get the odd pixelation issues described here on this forum - but not very often. Overall I'm very impressed with it - apart from the TV speaker issue - email from Sony :-
    Dear Mr Wyerd
    Thank you for your recent enquiry.
    I am afraid that speakers will default back to the original settings
    after the KD-32DX40 Television has been switched off. I would like to
    add that we cannot suggestion any modifications to our products to
    disable this feature. I am sorry if my reply causes some disappointment.
    Finally, if you need to reply to this e-mail, please quote reference
    72748444 in the subject field of your e-mail.
    With Regards
    Peter Shorney
    For and on behalf of
    Sony United Kingdom Limited
    Dissapointment is an understatement! I think that they should get their designers to listen to the customer.
    If you're thinking of buying one try www.unbeatable.co.uk I got mine for £888 inc P&P with a DVP-NS305 which I sold for £100 as I already had a player.
  10. roadtorode
    roadtorode
    Same on this see; damned infuriating, but at least you got a reply from SONY; they've ignored my query completely, although I only used the email query on their web site; these never seem to elicit a response.
    Good set ruined by this stupid feature. Why oh why don't the reviewers pick up these 'living with the set' issues rather than focussing 100% on the (agreeably very important!) picture/sound issue.
    Probably the same reason they never seem to mention the problems watching sky digital on a 100Hz set...Still, as long as youre over 10' away, you'll hardly notice..!
  11. w3dal
    w3dal
    Aug 4, 2002
    5,058
    Chelmsford, Essex
    +590
    Is Sky Digital Pants on these sets then??
    Dal :rolleyes:
  12. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    The integrated DTTV tuner produces a better picture than Sky:) :) :p :)
  13. HowieC
    HowieC
    Jun 9, 2002
    251
    London
    The answer to the internal speakers turning themselves back on when the set is switched on is:-
    Forget the speakers on off setting.
    Run volume to minimum
    Output audio from scart 3 with a scart - 2xphono lead
    On the fx66 set AV output to auto(in features menu)
    This will give audio output of whatever is on screen.
    Seasons greetings all.
  14. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    ARGhhhhhhhhhhhh!!! the DX40 only has 2 scarts.
    Merry Xmas to you all.
  15. super7
    super7
    Mar 20, 2002
    165
    Banbury, UK
    +3
    Wyerd
    Hadn't noticed this thread before, so apologies for the tardy response!
    Have a look at the the 'Sony speakers off?' thread (use the search button) - this has been covered.
    Bugged the hell out of me until I bought the Maplin catalogie. Never did make my own lead...
    Good telly!
    Super7
  16. Cakeboy
    Cakeboy
    Super7,
    I've tried searching for that thread, can't seem to find it.
    I've just added a HTSL5A (£270 from argos, pretty good for them!) to my 32DX40, and I've hit the 'speaker off' problem.
    How did you solve it ! Please help!
  17. super7
    super7
    Mar 20, 2002
    165
    Banbury, UK
    +3
    Cakeboy
    Have a look here.
    I'm pretty sure Maplin still sell the cable. Not had a problem with mine.
    Super7
  18. Cakeboy
    Cakeboy
    Thanks Super7,
    Thought that was how you'd probably done it.
    I had a look at Maplins and picked up a Scart through adaptor with phone in/out (gold plated as well :cool: ) WN53H for £6.49 , half price at the moment, which does the job nicely!!
    Thanks for your help,
    Cakeboy
