Audio Out: Headphone jack or iPhone port?
v CJ v
Joined
Dec 7, 2007
Messages
3,325
Reaction score
434
Points
668
Which is the best option to use for audio out (into an Amp or car stereo)?
Is there a benefit to either, or do both connections offer identical function?
E.g docks on the top of some stereos plug into the bottom of the phone, while your headphones provided with the phone plug into the headphone jack.
The dock out has much better sound quality because you bypass the headphone amp, which is the weakest part for the iPhones audio system. It also gives you a proper line level for use with external amps.
What Autopilot said :) I use a £5 dock stand off Ebay for the car.
The pin outs on the 3GS dock connector differ from earlier versions so make sure the dock/lead is compatible.
That's only for power though, I believe and was because the older iPod's used higher voltage power inputs. The audio and data output goes to the same pins.
Paul
Paul
I went through 3 dock cables (dock connector to 3.5mm) before I could get a peep out of my 3GS. I later found out it was due to the pin outs changing. I'm pretty sure the power connectors were changed too as mentioned above.
All a bit strange really because I have iPod docks (such as clock radios or boomboxes) that were released prior to the 3GS and they take their sound from the lineout and work just fine. However they won't charge the phone.
The pin layout for the 30 pin interface has been the same since the 3rd generation iPod's were launched. With that in mind, any correctly wired 30 pin audio interface cable will work with the iPhone, as long as it's designed for 3rd generation or newer iPod's.
It's a different story with video outputs but, that's an authentication issue, not a physical pin placement issue.
Paul
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
