Question Audio on my phone while using earphones is sometimes good and sometimes isn't
SmartChimp
I have Android 10, phone is Umidigi F2
Sometimes when I use my earphones audio is good but sometimes it's bad. I can't find any reason for that, for example I'll use my phone for some time while having earphones plugged in and audio is good, but after a couple hours I'll use my phone again and plug in earphones and audio would be bad and it would garble.
Any help would be appreciated! :)
Steven
Senior Moderator
Welcome
Try cleaning the headphone jack, no seriously. Also hear whether moving the wire between your thumb and forefinger causes the sound to cut out fade out, that may indicate a pending cable failure
That or it could be phone software related, something occurs every 'couple of hours'
SmartChimp
Welcome
Thank you for the time you spent on writing the answer and thank you for answering, I'll try that and hopefully it will fix the problem! :)
