audio note?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by iluvlesta, Aug 22, 2005.
  1. iluvlesta
    iluvlesta
    Aug 22, 2005
    34
    i'm currently using a cyrus IIIi and a smartpower.
    while listening to a cairn fog last week i had a listen to some valve amps too.
    any opinions on the following makes, audio note and croft?
    would i be silly to get a valve power amp and stick with the IIIi?
    what about buying them from abroad, for example the states? any negatives
    thanks
  2. iluvlesta
    iluvlesta
    Aug 22, 2005
    34
    have i put this in the wrong forum?
    sorry
  3. booktrunk
    booktrunk
    Feb 6, 2004
    623
    Leicestershire
    +3
    You might have more luck a few forums down in hi-fi seperates?
