Audio Missing DVD Architect 4
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by nizam, May 8, 2007.
  1. nizam
    nizam
    May 18, 2006
    240
    +8
    I have rendered a project using Vegas 7 rendered as MPEG2 and Template as DVD NTSC wide screen video , shown as audio none , How can can i get audio when i open it with DVD Architect 4 .Some one please help me , i would like to get audio AC3.
    Rgds
    Nizam
  2. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
    Nizam,
    Im still expecting something from you:(!
    Im not sure how Mark does it but If I wanted to use an ac3 audio from the video, I would go back to the project and render out the time line as an Audio
    file by choosing Dolby Digital AC3 in the Save as type drop down menu
    The resulting *.ac3 file should have an identical name to the Previously saved DVDA template mpeg file and where possible saved in an identical folder
    This saves DVDA from needing to rerender any audio later ( if present)
    If however if you render your video from Vegas ( or elsewhere) as an ordinary mpeg2 with "intergrated audio" ( not DVDA template) you can still render audio as ac3 for the DVD in DVDA.
    This will however make the process longer as DVDA will have to render out the existing audio ( PCM, mpeg ect) to ac3
  3. nizam
    nizam
    May 18, 2006
    240
    +8
    Thanks senu , but last time mark mentioned some thing about going in to DVDA and select replace under trackline , i cannote remember , can he explain to me that easiest way please.
    Rgds
    nizam
  4. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
  5. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Senu, Nizam
    I would do it exactly as you describe. If you render the audio out with the same base file name (xxx.mpg for the video, xxx.ac3 for the audio) in the same directory DVDA will find both and use them.
