Audio lead for Pc ??
Discussion in 'Cables & Switches' started by THFC, Sep 1, 2004.
  1. THFC
    THFC
    Feb 24, 2003
    242
    Gloucester
    +5
    Medion 5044 Tv Card Link to PC
    This card has a sound input and output internally on the Pci board. This is via a (small 4 pin header). I wish to connect the output to my Pc via the motherboard soundcard header (large 4 pin header).
    The motherboard has built in sound. The Tv card has an external line out but i would rather connect internally. Leaves my line in/mic free externally.
    Any one any ideas on what the cable is called or even better where i could get one??
    I tried the cable that you connect your motherboard sound card to the audio out on my DvD Rom drive. But the header on the Pc Tv card is too small for a fit. It connects to the motherboard though.
    Any help appreciated, i have searched all over
