Audio keeps cutting out?
Discussion in 'AV Receivers & Amplifiers' started by iMan, Feb 11, 2005.
  1. iMan
    iMan
    Mar 30, 2003
    34
    I have a home cinema projection system based around a Mitsubishi DLP projector and a 7 feet screen. The problem is with either the receiver or dvd player (in progressive scan mode), both are JVC.
    I'll be watching a film and every now and then the sound will cut out totally for about 1 second, not much, but if it happens during a piece of dialogue you can miss 2 or 3 words. It happens randomly and there is no strict timing as to when it does it. On average it will happen between 3 and 7 times throughout a film and I haven't got a clue why it happens.
    The system components are as follows:
    Mitsubishi dlp projector
    JVC XV-NA77 dvd player
    JVC RX-5032V receiver/amp
    Keff Egg KHT2005.2 speakers and subwoofer
  2. bobbypunk
    bobbypunk
    is the cable faulty?
    is it optical or coaxial?
    if it's coaxial is it a 75 ohm shielded lead?
  3. Docta teef
    Docta teef
    Nov 21, 2003
    1,257
    Manchester
    +56
    Check all cable connections ( you may well have done this)
    Is there any video jitter at the same time?
  4. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    What connection are you using between receiver and DVD player? It could help to replace the cable.
    If you use coax make sure it's a "digital cable" with 75 Ohm impedance (a proper video lead will do as it has 75 Ohm, too).
  5. Minivan
    Minivan
    Feb 2, 2005
    97
    11
    I have the same thing happening to me when audio is running through the optical lead. I have a 10m lead that was only about £10, so i think it's probably a crap lead. When I switched to analogue for tunes on vinyl, it didn't cut out once.
    I am going to get a high quality optical lead and think this should resolve it.
