Audio issue with Samsung LN-S4051D
D
dpf1978
Hi folks,
I'm new to this forum but it seems like the best place on the web to get good technical info.
The problem I'm having is this:
I purchased a Samsung LN-S4051D 40" LCD television last week. Everything works great but when I connect an auxiliary audio source, the auxiliary audio is a few milliseconds behind the sound coming from the television, causing an echo/layering effect that makes it impossible to enjoy what I'm watching.
I've tried 2 different DVD players and 2 different stereos with the same results in all cases. I can only think of 3 possibilities as to what is wrong:
1. The Samsung LN-S4051D plays DVD audio much lower than regular television and game audio--and maybe all stereos/surround sound setups have a delay but the low TV volume is making it much more noticable?
2. There is something wrong with the audio-out on the TV and I need to contact the manufacturer or return it to the store. (Oh god, I really hope this isn't the problem.)
3. The audio cables I'm using are at least 5 years old and are causing the delay. (I've used the same two sets for all my tests but they are both 5+ years old)
The audio cables I'm using are your standard red and white cables.
Any suggestions short of returning the TV or having Samsung send a technician out?
Any help would be MUCH appreciated.
D
dpf1978
As I read through the forums I'm getting the impression that audio delay is pretty common with an auxiliary device...is that correct?
D
dpf1978
Oh this is just fantastic...I just called Samsung and they told me I need to return the TV or have a technician come out. I guess not it's not normal for there to be a slight audio delay when you connect a stereo to the TV.
D
dpf1978
So, before I return this to the store, can anyone think of any OTHER reason why I would be getting an audio delay on the stereos and why the DVD audio would be so much lower than the TV and game audio?
