audio interconnects from sky to a/v amp
Discussion in 'AV Receivers & Amplifiers' started by menalaus, Apr 26, 2003.
  1. menalaus
    menalaus
    Apr 25, 2003
    338
    sleepy hollow
    +6
    any recommendations for an upgrade (from the freebie bell wire) interconnect from the L/R audio out on my Pace digibox to my yamaha 430 ?
  2. MikeK
    MikeK
    There are those who will tell you that spending a wad of cash on an expensive interconnect will transform your lowly Pace STB into a high end hifi component, and there are those who'll tell you it will almost certainly make sod all difference!
    I'm one of the latter! :)
    If you feel the need though....:), personally I really wouldn't spend more than £5-10 (dep on length) on a premade shop bought "upgrade" for this purpose!
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    RS do some cheapy Phono cable but a big difference is unlikley!!! may upgrade anpther set of phonos and use the old ones for the pace box!
