audio furniture
Discussion in 'Home Cinema Building DIY' started by Tonmeistermat, May 27, 2004.
  1. Tonmeistermat
    Tonmeistermat
    Jan 10, 2003
    178
    Blackheath (UK)
    +3
    Hi all, I am about to build some furniture for our home studio, and am after some advice... we need the surfaces to be at aboout .65m high, and I'm having trouble sourcing legs that length (they are all either .4 or .71!). Any ideas?
    Also, thinking of using double thickness 18mm MDF - I'm not sure if it will be rigid or strong enough... any thoughts?
    I'm sorry it's a little off the usual sort of thing on this forum, but I was wondering if anyone had any ideas!
    thanks,
    Mat
  2. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Ikea do some variable length legs?
  3. Tonmeistermat
    Tonmeistermat
    Jan 10, 2003
    178
    Blackheath (UK)
    +3
    Thanks mate, they are also too long! WIll keep looking....
  4. nathsea
    nathsea
    Apr 26, 2003
    920
    +24
    had a look on the b&q site and they do some legs although they are the sizes you mentioned above, but carried on looking and they had legs that are used for breakfast bars in kitchen installs. Could you cut the bottom of one of them ? Would that look OK? or do you want something more shapely??
    Nathan
  5. Tonmeistermat
    Tonmeistermat
    Jan 10, 2003
    178
    Blackheath (UK)
    +3
    Thanks Nathan,
    Went to B&Q this morning and checked them out properly - it would be possible to chop the bottoms of them, but I suspect it would get messy! There are going to have to be about 25 of them, as the furniture is going to be modular and will need extra support for load bearing... As time passes, the project is getting more and more complicated, and am on the verge of getting a proffessional joiner to help me out... the last thing I want is for the whole lot to collapse and dump all my gear in a heap on the floor! :laugh: Am still looking at options though, so thanks for the thought...
    best,
    mat
  6. nathsea
    nathsea
    Apr 26, 2003
    920
    +24
    blimey that must be some studio!! ( will be nice to see some pics - as always). If I have any more useless ideas i`ll let you know :)
    Nathan
  7. Tonmeistermat
    Tonmeistermat
    Jan 10, 2003
    178
    Blackheath (UK)
    +3
    :) My partner has started working from home (he's a composer and sound designer), and the current home studio doesn't quite have the grunt needed, hence this project... The room is going to double as a 5.1 cinema room once we are done too, so it should rock! As we get going I'll definately start posting some pics...
    Mat
