According to your TV's user manual it has an (analogue) audio input between the 'DVI Input' port and the 'RGB Input' ports. It's most probably a 3.5mm stereo type.
Depending on the model of YouView box you have you might be able to use a basic '3.5mm to Twin Phono/Stereo Cable'.
Looks like the tv has a 3.5mm input jack
if so you need a 2x Phono - 3.5mm jack cable for the audio
You can get the user manual here
LG Support Search Results | LG U.K.
the attached pic is from the manual
hope this helps
Hi guys,
Thanks for your replies. Yes, on the back of the tv is the 3.5 mm 'mini' jack. But, on the back of my Youview box, besides the SPDIF and antenna outs, I only have an hdmi out. So I can't use a '3.5mm to Twin Phono/Stereo Cable'/"2x Phono - 3.5mm jack cable for the audio" as suggested. In other words, there's not an output for audio on my Youview box.
What I have tried so far is this:
1. HDMI from Youview box to DVI into the TV for video, with a SPDIF out of the Youview box into the mini jack into the before mentioned audio jack on the tv for audio. The mini jack end of the SPDIF to mini jack cable doesn't click all the way into the mini jack input on the tv. The male end of this mini jack isn't long enough. All the cables I've seen look the same. (If you look closely at a picture of these SPDIF to mini jack cables - toslink cables - you can see that the mini jack end isn't the same as a normal mini jack. It's shorter.)
2. SCART from Youview box to tv but the picture shakes, or trembles, slightly. No good.
3. HDMI out of the Youview box into a 3-jack composite cable (red, white, and yellow jacks) into the corresponding jacks on the tv. This is "AV3". I get a "No Signal" message on the tv screen, so basically nothing. And yes, I've switched the AV settings to "AV3".
Option number 3, the HDMI to composite jack cable, was the option that I thought would finally work, but no luck.
Am I missing something completely obvious? I'm stumped.
