Audio from VGA to HDMI cable on a Sky box?
Discussion in 'Sky Digital TV Forum' started by blackfalc0n, Aug 6, 2013.
  1. blackfalc0n
    blackfalc0n
    Feb 5, 2011
    191
    London
    +5
    Just got a new Sky+ HD box and now we've got nothing to do with the old box - a Panasonic TU-DSB30. It's got a VGA connection so I was thinking about getting a VGA to HDMI cable for it so it upscales to HD on the small TV upstairs. Going to put Sky Freesat on it and don't want to buy a HD box that'd be too expensive, so a cheap upscaling alternative like that is better. :)
    Anyway, will a VGA to HDMI cable like the one below I'm thinking of buying for the box transmit audio or only video? I'm not sure if VGA transmits audio thats why. Also do you guys think this is a good method of upscaling the SD box to HD? I would use normal Scart on the TV but the quality is just appalling. :p
    http://www.amazon.co.uk/HDMI-Male-S...F8&qid=1375814190&sr=1-2&keywords=vga+to+hdmi
    OH and although this cable is HDMI to VGA, will it still work the other way? (VGA to HDMI?)
    Thanks. :D
  2. Philip4242
    Philip4242
    Jan 15, 2008
    1,021
    UK
    +167
    Sorry, but it HASN'T got a VGA connection !
    What you've seen on the back of the box is an RS232C (serial) connector, which is the same physical size as a VGA connector, but has only 9 pins, rather than the 15 pins on a VGA (video) connector.
    The RS232C connector is used for servicing, and CANNOT be used for any other purpose.
  3. JayCee
    JayCee
    Jan 20, 2004
    23,504
    Lanarkshire
    +2,534
    Notwithstanding Philip4242's excellent and correct answer you cannot use a cable like that in any direction.
    VGA is analogue and HDMI is digital...you would need a black box convertor.
  4. HD sceptic
    HD sceptic
    Apr 1, 2009
    814
    28
    Glasgow
    +81
    I don't remember VGA ports supporting audio either, you usually need a separate cable for that
  5. blackfalc0n
    blackfalc0n
    Feb 5, 2011
    191
    London
    +5
    OH, my bad. :rotfl: Guess that answers my question. :facepalm:
