Audio from TV to hifi
Discussion in 'Hi-Fi Stereo Systems & Separates' started by aybsee, Feb 13, 2014.
  1. aybsee
    aybsee
    Feb 13, 2014
    Hiya,
    I have a samsung smart tv with the only audio out function is a digital optical audio socket. I want to play the audio through a Sony hifi and the only audio in function is a 3.5mm stereo jack socket. Is there a cable that can support that or do i need to buy something else? thanks
  2. Silverblack
    Silverblack
    Sep 24, 2008
    3,068
    +578
    Yes you can get a 3.5mm to RCA cable amazon sell these very cheap, or alternatively you could get a cheap dac which you would connect an RCA cable to from your hifi to the dac then an optical cable from the dac to the tv.
    Hope this helps.
  3. PIEP
    PIEP
    Feb 15, 2011
    FLORENCE, ITALY
    +14
    Or you link the hifi to the TV's phones output
    with a 3.5mm stereo jack-jack cable ...
  4. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,352
    +4,211
    Could you tell us specifically what Sony HiFi you have? It seems very unusually that the HiFi would have a 3.5mm Stereo Input.
    To make this work, you will likely need a DAC (Digital to Analog Converter). Depending on how much you want to spend, the prices can vary greatly -
    On the low end -
    Superfi - CYP AUD1 DIGITAL TO ANALOGUE CONVERTER
    Superfi - CYP AUD3 DIGITAL TO ANALOGUE CONVERTER
    And prices go up from there. One of the above is combined Optical and USB, the other is combined Optical and Coaxial. Either one will work.
    Steve/bluewizard
  5. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,352
    +4,211
    Curious does your TV has a HEADPHONE output, because that could be used to drive you Stereo directly; no need for a DAC?
    Steve/bluewizard
