Audio from a PW7
Discussion in 'Plasma TVs' started by simon33, Jul 8, 2005.
  1. simon33
    simon33
    As some of you may know, I'm considering buying the Panasonic pw7.
    One question though, does it have audio out in any form?
    Thanks! :)
  2. vileda
    vileda
    Oct 15, 2004
    401
    Sunderland, Tyne & Wear
    In a sense, but you need a dedicated amp for a reasonable experience
  3. Mep
    Mep
    Dec 25, 2004
    9,551
    +472
    it has its own amp built in for the speakers...but vileda is right go the seperate amp route
  4. simon33
    simon33
    I'll most definetly be going for the amp in the future, but for a month or two until I can get the cash together for a decent one I'll go down the route of some cheap speakers.
    Can anyone let me know how I'd connect them?
    Thanks.
  5. Mep
    Mep
    Dec 25, 2004
    9,551
    +472
    just spring clip connections
  6. simon33
    simon33
    Thanks mep.
    Am I correct in thinking that you'd connect the amp to these spring clip connections?
  7. Mep
    Mep
    Dec 25, 2004
    9,551
    +472
    no just speakers....when you get the amp you just conect your equipment directly to it and the speakers hang off the amp
  8. vileda
    vileda
    Oct 15, 2004
    401
    The sound goes from your source to the terminal board via phono leads in the case of the component etc, the scart lead carries the sound as well in the case of the scart board.
    the pictures of the terminal boards here at AV-Sales may make this a bit more understandable
  9. Mep
    Mep
    Dec 25, 2004
    9,551
    +472
    yep
  10. simon33
    simon33
    Thanks mep and vileda, you've both been really helpful. This is all a little harder than I expected!
    With regards to the terminal boards, which ones do most people choose to purchase?
  11. vileda
    vileda
    Oct 15, 2004
    401
    It depends what you want to do....
    Thats the benefit of a display over a TV, you can set things up the way you want it, the flip side is that you need to work out what you want to do first.
    It is really daunting at first and we all make mistakes but that is what the forum is about, learning from one another.
    If you list what you want to connect and perhaps a rough budget for things you want I'm sure you will get help. . . you are asking about a panny afterall :D :D :D
  12. Mep
    Mep
    Dec 25, 2004
    9,551
    +472
    yes.....we have a little experience :)
  13. simon33
    simon33
    I was originally going to go for the LG as it seemed a quick and simple option, but after seeing the picture from a Panny I decided it was worth putting in the extra work to get a decent setup.
    I'm completely daunted after looking at the terminal boards, it seems the names of connections certainly aren't my strong point. In all, I wish to connect a VCR and a freeview box. I also need to connect a DVD player and 2 consoles (an xbox and a ps2).
    The help so far really is much appreciated. Thanks. :)
  14. Mep
    Mep
    Dec 25, 2004
    9,551
    +472
    realistically you should ditch the vcr and get a dvdr..you'll never get anything great from vcr......and as you want to make the effort i would suggest the js rgb to vga converter for your freeview...a component board for your dvd/r....and i would go for a scart splitter and plug freeview and teh consoles into that...then connect the scart splitter to the js rgb to vga and that to the screen
  15. vileda
    vileda
    Oct 15, 2004
    401
    What Mep Said is good........................
    I'd already written the below
    Ok,
    I don't believe that a VCR will be up to much picture wise.
    What connections do you have on the Freeview & DVD player??
    Someone else (Mep??) will definately have answers for the consoles
  16. vileda
    vileda
    Oct 15, 2004
    401
    So for this you would need the following;
    TH42pwd7> £1300ish
    Component board £50 (if bought with the screen at AV Sales)
    dvdr> £140
    JS rgb-vga> £127
    Scart Splitter> £80 (i'm guessing about this one)
    So that's about £1700 before cables where you can spend as much as you like
  17. simon33
    simon33
    Thanks mep and vileda.
    As the budget just about stretches to the plasma, I'll be getting the DVD recorder in perhaps 6 months time. I'm willing to put up with the bad quality picture from the VCR for now. :)
    The DVD player will be ordered at the same time as the plasma, so connection wise I guess I'm fairly flexible. The freeview box is the Sony one everybody seems to have, it connects to scart.
    Thanks again for your help so far, you're definetly making this an awful lot easier...!
  18. bellyfluffer
    bellyfluffer
    sorry to jump on someone elses thread, but thinking of the pw7 myself and needed to ask a "nebie" question....
    what if any is the differance between a pw7 and a pwd7?
  19. vileda
    vileda
    Oct 15, 2004
    401
    It's been a while since I heard that question.
    try a search on pw7 difference pwd7
    here's 3 for starters
    http://www.avforums.com/forums/showthread.php?t=188295&highlight=pwd7+difference
    http://www.avforums.com/forums/showthread.php?t=187169&highlight=pwd7+difference
    http://www.avforums.com/forums/showthread.php?t=186555&highlight=pwd7+difference
    Be prepared for a couple of hours reading :)
  20. bellyfluffer
    bellyfluffer
    thanks for that looking now!
    just started a new thread in last min, would appreciate your advice on that too
    thanks again!
  21. bellyfluffer
    bellyfluffer
    read it and realise how daft a question it was with so many threads already
    thanks for the patience!
  22. vileda
    vileda
    Oct 15, 2004
    401
    I'll leave the answer to that one to someone who has 1st hand experience of the various screens
  23. simon33
    simon33
    Can anybody tell me what connections the PWD7 has 'out of the box'? Does it have VGA?
  24. vileda
    vileda
    Oct 15, 2004
    401
    It has VGA built in.
    I'd recommend getting the dual slot Component/Svideo/Composite board as well as it gives options for further expansion.
    (you could even connect your vhs via scart-composite for the short term just to prove that the picture is big but not good!!!)
    are you thinking of wall mounting or going for a desk mount?
    Before I go on, I must admit that I'm biased as I got such good customer service (was $h1t scared at spending £2k on a monitor!!!) with AV-Sales.com so even though I recommend them there are other slightly cheaper options. I'd still pay the extra 5% and go for av-sales though.
  25. simon33
    simon33
    Thanks vileda, you've been so helpful.
    I'm thinking of going for the wallmount. :)
  26. vileda
    vileda
    Oct 15, 2004
    401
    How do you connect your PS2 & Xbox at the minute?
  27. simon33
    simon33
    Using the yellow, red and white leads. I'm sure that's got a name!
    However, from what I've heard scart is far better...
  28. vileda
    vileda
    Oct 15, 2004
    401
    with those it's only the yellow that carries video, the other two the left and right sound channels. The yellow cable carries a composite signal.
    There are a few different ways to connect up the xbox & ps2, in the meantime I'm sure you could connect via Composite or (better) Svideo, as long as you don't mind swapping a cable between consoles. There are other threads about how to connect consoles via hd etc, which you can look at when you get your amp.
    That would leave the freeview to be connected via a JS RGB>VGA converter and a cheap dvd to be connected via component.
  29. vileda
    vileda
    Oct 15, 2004
    401
    I'm sure this has changed but generally the order of quality is
    Lowest
    Composite
    svideo
    RGB
    Component
    Highest
    It gets much more confusing than this but I think it is a good start.
  30. simon33
    simon33
    I'm going to cheekily use this post to get my connections up to scratch...
    Composite is the yellow cable, normally included with the red and white for audio. S-Video is the round connector with a couple of holes in, often used for pc to tv.
    Could you please fill me in on the RGB and component leads? A quick Google throws up mixed results. :rolleyes:
    Also, where abouts would scart come on that list - or have I missed it due to all these cryptic names!
    Thanks so much again.
