audio extraction
Discussion in 'Desktop & Laptop Computers Forum' started by Lovetrooper, Jan 16, 2003.
  1. Lovetrooper
    Lovetrooper
    Is there any software available that will let me extract audio from a DVD on my pc?
    Cheers,Glenn
  2. fraggle
    fraggle
    Dec 11, 2002
    1,456
    Milton Keynes
    +33
    [Moved to more appropriate forum, Fraggle]
  3. Beastie Boy
    Beastie Boy
    Give VOBEdit a try. Get it at http://www.doom9.org/. You may need to 'rip the DVD to your HD first. Use SmartRipper or DVDDecrytor for this.
    Once the files are on the HD, you could use DVD2AVI. Simply select the first VOB of the movie and press OK to load the related files. Then select File\Save Project. The audio will be saved as a seperate .ac3 file.
    I f you only want the audio from the main movie (not the extras etc) then use Movie mode in SmartRipper to save HD space.
    Cheers, Beastie
