Hi guys,
I have a new CXA81 abs use two inputs, a Node 2 via Digital Coax and my Samsung TV via optical.
Problem 1 - At the start of starting a Amazon music stream through blue sound. I’ll get an audio dropout 4/5 times every 30 seconds or so and then disappears for good.Writing this now and I’ve been intending for 30 mins plus without a hitch. Any thoughts?
Cable is old. 6 years ish.
Problem 2 - Intermittent dropouts with the TV. Normally happens every ten or fifteen seconds. If I change the sound output from tv to optical it normally goes away. Or if I reset sound settings it seems to go away. Then it can be fine for 20 minutes and will randomly come back. I’m wondering if it’s the tv or cable for this reason. If it were the DAC I think it would happen more often? Ps the cable is long and about 6 years old. Can they degrade?
Thanks ever so much for your help.
