Audio delay on (optical) DVD start
Discussion in 'AV Receivers & Amplifiers' started by hangleton, Jan 22, 2004.
  1. hangleton
    hangleton
    Dec 16, 2002
    13
    Hello,
    This problem has been bugging me for a while. Apologies if this is a regularly asked question or the solution is really obvious, I'm a bit new to this game.
    I have recently upgraded to a proper surround system, using an aging Sony 315 DVD player and Denon 1803 Amp. The connection between the two is via an optical cable.
    When starting to play a DVD, there is a delay between the DVD start and the audio being generated. Just 1/2 a second or so, if that.
    It's not noticable on films, but on many extras, like interviews etc, it's really annoying.
    This problem does not happen using analogue cabling.
    Has anybody else come across this? Is it my DVD player or amplifier that is causing it, and is there any way to get round it?
    Thanks in advance, hope this makes some sense
    Andy
  2. mjn
    mjn
    May 24, 2001
    21,444
    Herts, England
    +9,004
    probably just the amp getting synching to the signal being sent from the DVd player.
  3. balders
    balders
    Jul 31, 2001
    451
    28
    +25
    mjn's probably right. With the optical digital cable, there are probably a variety of signal types that can be sent to your amp - streo, DD, DTS, etc, and your amp is detecting the different types and switching (may be accompanied by a click) as appropriate.
    I guess this doesn't happen with analogue (left/ right) cable because you're only getting one type of signal (stereo), so there's no need for the amp to switch.
    Balders.
