audio - co-ax or optic?
Discussion in 'General TV Discussions Forum' started by David Burns, Dec 8, 2004.
  1. David Burns
    David Burns
    Hello there,
    I'm wondering, - to connect my dvd player to my tv amp (built-in) is it better to use the co-axial connection or the optical connection?
    Or to untrained ears are they pretty much the same?
    :smashin:
    Thanks,
    David B.
  2. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    David,for a fuller answer,it may be worth doing a search here on this topic(or may be worth our while in making a sticky to hold some of the details).
    In theory,Co-axial is capable of delivering better quality,but at the level of TV amps/decoders,it really wont matter which you use.
    FWIW,I use an optical cheapy line for my DVD to TV link,and good quality Co-ax digital interconnects for HCPC/DVD/Sky+ links to my processor.
  3. Astaroth
    Astaroth
    Jun 22, 2004
    3,653
    2
    London
    +882
    There is very little difference if the cable is short (less than 2m).
    'Traditionally' it is said that co-ax is better for less than 2m and that optical is better for over 2m.
    I personally use co-ax for all my digital connections with the exception of when I had my PC linked to my amp (which was 5m away) which I did use optical as when I compared it to a similar priced co-ax there was a noticable difference in quality
