Audio Capture
Discussion in 'Desktop & Laptop Computers Forum' started by richjthorpe, Sep 13, 2005.
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    Hi guys,
    I've got a laptop with microphone input capability (3.5mm phono jack). I DJ a bit and I want to record a set on the laptop. Would I be able to connect the phono output from a mixer (2 line level phono analogue) to the microphone input on the laptop and record it straight to the hard disk ?
    If so, can anyone recommend a piece of software to use to do the recording and also for editing ?
    Many thanks,
    Richie.
  2. deksawyer
    deksawyer
    May 26, 2005
    1,634
    Fife, Scotland
    +132
    Yep, no problems with what you want to do.
    I used to do live webcasts and used Real Encoder (Helix) & Windows Media Encoder.
    There were used to stream over the 'net. but they can encode locally on your hard drive as well.
    You could look for Sound Forge - more of a dedicated recording/editing suite. You might be able to get a free limited download.
    D.
