What kind of A/V unit do I need to make this work and do I need to by front facing speakers or will the built in ceiling speakers do the job?
With the crazy cables, I completely missed your other question. Any AVR will do for the most part. Newer AVRs are quite expensive atm, but drop back a few models and there are bargains available. But which to get, depends on what you want to get out of it. Do you want 5.1 surround with 4 ceiling speakers i.e. 5.1.4. or do you want 3.1.4, 5.1.2, 7.1.4, 7.1.2 etc. Take a look at the dolby guides below to see what speaker setup you want. Personally i would get 5.1 as a minimum, but as you have ceiling speakers in place, 5.1.4 is good for you. The question then is which AVR, 5.1.4 needs 9 channels (5=4 = 9), which say 5.1.2 or 3.1.4 only needs 7 channels. Many budget AVRs cap out at 7 channels, like the denon x1700, x2700, but these are still limited to 2 ceiling speakers, so 5.1.2 is possible but not 3.1.4. If you want the 4 ceiling speakers you'll need something like denon x3600, x3700, x3800, x4600, x4700 etc. If you can set a budget for what you want, and what speakers you have available (if any) I can try to see what works.
Here is a pic of how my room is setup -
Denon X3800H Owners Thread
First off, if you want good sound, your left, right, centre channels should be in front of you, not the ceiling. So personally, i would buy 3 speakers for the front to go around the TV. And use 2 in the ceiling above the TV for atmos (Top Front). (Leaving the 3rd speaker unused)
Now for the 4 speakers above the sofa. Honestly, not sure why they put in 4 speakers. You only need 2. I would wire up the 2 outer most speakers for atmos, and leave the inner two again unused. You could but i wouldn't recommend it, use the outer 2 for surround and the inner 2 for atmos (Top Rear). Surrounds, need to be at ear level, like the left/right speakers around the TV.
Personally i would get separate speakers for use as surrounds.
Browse our wide-range of Dolby Atmos speaker step-by-step setup guides to find the best speaker placement and configuration for your home theater.
www.dolby.com
Learn how to set up Dolby Atmos 5.1.4 overhead speakers for an immersive Dolby Atmos experience. Get professional tips and guidance for optimal speaker placement.
www.dolby.com
