Audio but no video
Discussion in 'AV Receivers & Amplifiers' started by pligs76, Jun 3, 2002.
  1. pligs76
    pligs76
    This question has surely been answered before, but my search has failed to find the answer:
    Have just entered the world of surround sound and not fully dry behind my ears.
    Have connected my 2 x SAT receivers, 1 DVD and 1 x VCR to a Sony 1070. Except the VCR all video connections are connected with S-video. The video of the VCR is connected with normal phono cable.
    The connection from 1070 to TV is via S-video + phono (sound).
    Now: how do I get video from the VCR? The sound is OK but there's no video, even when I connect the 1070 and TV with both a s-video and phono cable (video)
    I am surely making a basic error here - but which?
    Thanks for your help.
    Pligs76 (newbie)
  2. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    If the VCR will not output s-video you will have to conect it for composite video output. Is there a yellow phono socket somewhere on the back which you need to connect to the VCR phono input on the amp with a further phono connection from the amp (monitor out) to the TV.
    Alternatively you can use a scart - three phono cable plugging the scart into the back of the VCR and the two audio and one video plugs into the amp.
    The composite video and s-video outputs on the Sony are not on the same bus and if you are using both connections you will need to output them seperately.
  3. pligs76
    pligs76
    The VCR is only connected to the Receiver via phono cables (L+R+Video) in both directions. I have not connected the VCR directly to the TV. Neither TV nor VCR has Scart (Asian models)
    Is it a setting on the receiver I need to program to enable output of both composite video signal and S-video signal? or am I on the wrong track here?
    Pligs76
  4. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    The s-video output from the receiver to the television will only send video signals that are in s-video.
    The VCR will not output an s-video signal so it needs to be connected seperately to the receiver by plugging the yellow phono cable into the VCR and VCR input on the receiver.
    I think that you have done this already but you will need a further connection from the receiver to the TV to carry the video signal as it cannot travel down the s-video cable.
    There should be a Monitor Out (yellow) socket on the Receiver which needs to be connected to a composite video input on the TV
  5. pligs76
    pligs76
    Thanks Ian,
    Know exactly what to do now.
    Fantastic response time. Highly appreciated.
    Pligs76
    :D
  6. Doubledoom
    Doubledoom
    If your tv has 2x phono output, you could take all the audio from there to the amp with the exception of the digital audio sources.
    This saves a lot of cabling, gives you the chance to have the best video signals and saves audio switching on your analogue audio sources.
