audigy2 probs
Discussion in 'Microsoft Windows' started by ciamcool, Nov 5, 2005.
  1. ciamcool
    ciamcool
    Sep 10, 2005
    29
    3
    hope you guy's are gunna sort this for us :thumbsup:
    i've got mce up un running fine but i've got an audigy2 zs sound card and want to be able to connect it to my av amp for dd/dts.now the s/card has spdif output but my av amp only has optical and coaxial input's :mad: .....so do any of you folks know of a cable i can purchase?? i been told creative do one, i've looked on the web site but cant find anything.
    :lease: i need your help here :thumbsup:
    cheer's
  2. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    you need to connect a 3.5mm phono to coxial cable from the digital out of the audigy to the coaxial in on oyur amp, it's not know to most people, but it does work, and you won't see the cable in mosts shops...
    Link removed
    refering to the above post, you should be able to get a 3.5mm to phono adapter from mapln then just run a coaxial cable from that to your amp,
  3. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    The information required is in the handbook which is on the website if you don't have one to hand, it describes the lead as follows:
    As meansizzler stated, a 3.5mm mono to phono(femail) adapter with a normal phono to phono digital cable will do the job.
  4. ciamcool
    ciamcool
    Sep 10, 2005
    29
    3
    but it has to be four pole?? that's what it say's in the manual,also went to maplins and they said it was a creative part and then went to a dedicated hifi shop and they didnt do the lead so i thought i would put a post up to see if anybods have connected there s/card to their amps
    cheers
  5. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    I have a dedicated 3.5mm to phono cable, came with a bunch of Boston Acoustic BA635 Digital Speakers, os you werein maplin why did you not buy the stuff we told you to get?...
  6. ciamcool
    ciamcool
    Sep 10, 2005
    29
    3
    o.k just been on the maplins web site and is this what i need quickfind code N86AN and i already have a coaxial cable.
    also i was in maplins yesterday b4 i put a post on here,that's why i asked for your help lads as i thought it was a lost cause @ about 5.30 last night after listening to what maplins/hifi shop said
    cheer's for your help lads
    ps as i like to get "the best if poss" in cables and wot not just want to make sure i'm buying the correct bits
  7. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    It looks right to me. I can't see how it needs to be four pole and that certainly isn't what the illustration I downloaded indicated. And the description I posted was pasted straight from the document. Definately says 'mono'. Buy with confidence. :)
  8. Pbryanw
    Pbryanw
    Nov 15, 2004
    1,525
    N.E. Lincs
    +103
    If you like to get the best why not try the Mark Grant Digital Coax Interconnect available on this site:
    http://www.avforums.com/forums/showthread.php?t=101717
    It made a definite difference to my system.
