audigy zs dolby digital out
Discussion in 'Desktop & Laptop Computers Forum' started by tim k, Sep 9, 2005.
  1. tim k
    tim k
    ive re-installed my pc, have the digital out connected via coax to my denon amp. but unlike my sky on dd it doesnt switch when i put a dvd on, cant work it out. i have enabled it in the settings to spdif out and running ac3 filter with spdif disabled ticked and 5.1 and pcm 32 bit and all boxes checked in system. can you pls help me!!
  2. meansizzler
    meansizzler
    May 11, 2005
    7,582
    104
    London
    +266
    You have to enable SPDIF in AC3 filter, also go to the Control Panel>Audio HQ>Device Control>Decoder and disable the AC3/DTS Decoder select *AC3 Passthrough*, what dvd player do you use?, if it still does not work try a different one like Nvidia Purvideo and also select SPDIF passsthrough on there from the Audio Properties..
  3. tim k
    tim k
    i had every part checked except the audio hq. perfect running dd5.1 now on my spanking kef 5005s, sweet!! thanks mate.
