Audigy z2s. digital output to digital input on processor? 5.1 sound in games?
Discussion in 'Computer Components' started by Maninblack, Dec 28, 2004.
  1. Maninblack
    Maninblack
    Sep 24, 2002
    446
    +15
    Will this soundcard give digital surround sound in games(5.1 or higher) to a digial coaxial input on a parasound c2,
    or will I have to use the analogue outputs on the soundcard and analogue inputs on the c2??
  2. stlic
    stlic
    Feb 17, 2004
    744
    +15
    No on the fly DD encoding so analogue only I'm afraid.
  3. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,469
    Southampton
    +188
    True - analogue only.
  4. Maninblack
    Maninblack
    Sep 24, 2002
    446
    +15
    MM. I going to have to sort out the correct cabling then for 5.1 0r 7.1 sound. Distance is 7 metres.
  5. Yaka
    Yaka
    Dec 20, 2000
    1,682
    2
    63
    +115
    DD only in films. Nforce 2 soundstorm is the only chip that does on the fly 5.1 sound in games
  6. Maninblack
    Maninblack
    Sep 24, 2002
    446
    +15
    With the three analogue outputs from the soundcard. How can I correctly connect them to the analogue inputs on my C2?
  7. Maninblack
    Maninblack
    Sep 24, 2002
    446
    +15
    OK.
    Happy new year!
    Ok I have a digital RCA cable.
    Plugged into a mono to RCa converter at sound card end plugged into spdif.
    Then into Digital 3 on parasound.
    Parasound OSD reports this as PCM.
    Using test tones on sound card I only get stereo output using any selection of outputs, 5.1, 6.1, 7.1 etc. I only hear front left and front right.
    Switching source on parasound only shows mono or stereo.
    WHat am I missing to get the other test tones, centre rear sub etc??
    Help!! Perhaps I needed to select 'direct' mode but mrs hogging TV now!
