AUDIGY sync problem
Discussion in 'Desktop & Laptop Computers Forum' started by (GTV)Chris, Aug 21, 2003.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    695
    Manchester
    HCPC
    Radeon VE graphics
    Audigy player
    Theatertek DVD player
    Pioneer 106s
    I was watching a movie and skipped a few scenes ahead then all hell broke loose.
    It all went about 5 seconds out of sync.
    I have it set to gigital out and have TT set to Spdif and selected the output device as the audigy.
    Running Win2k.
    Why is this happening, I am getting fed up with HCPC's now :(
    Is it worth me getting a pure digital card? If so which one....I aint got a lot of money.
    Chris
  2. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    695
    Manchester
    Has noone experienced this problem????
    What digital audio card are you all using?
    C
  3. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,000
    48
    Reading, Berkshire
    +54
    Have you tried selecting directsound audio device or waveout audio device?
  4. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    695
    Manchester
    yes i have it set to direct sound.
    It seems to have settled a bit but I still feel that it looks a frame or two early, which is worse than a frame or two late :(
    I may consider changing it for a pure digital card....If I have the money.
    Ta
    C
  5. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    The card shouldn't matter. if it works it works but it sounds like you have some other system process thats hogging resources and throwing everything out of sync. Theatretek likes things smooth and doesn't seem to be very robust when they're not.
  6. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    695
    Manchester
    Thought as much.
    Is there a way of deleting all things not needed from the system to make it run smoother and boot up quicker??
    At the mo my Win2000 takes a while to boot up.
    All I need is TT, descaler, wintv and that's about it.
    Chris
  7. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Personally I'd start with a format and clean install but if that beyond you then aggogle search for "remove services" will turn up loads of guides, mostly xp orientated but mostly applies to w2k as well.
