Audigy 2 ZS S/PDIF Output pins
Discussion in 'Desktop & Laptop Computers Forum' started by DaveP, Mar 3, 2005.
  1. DaveP
    DaveP
    To cut a long story short I've got an Asus S/PDIF optical and co-axial output connector for an Asus mobo. I've also just bought an Audigy 2 ZS.
    Now the thing is that I only have an optical input available on the receiver and, of course, the Audigy only outputs co-ax "out of the box".
    So the question is: can I connect the Asus device to the Audigy?
    The Asus board has a three pin connector and and is suppled with the appropriate connector cable.
    The pins are labeled +5v, spdif out and Ground. Does anyone know what the pin-outs are on the SPDIF_IO connector are on the Audigy?
    Dave
  2. DaveP
    DaveP
    Well for anyone who is interested here's where I've got to:
    My Audigy arrived yesterday and I found a site that listed all the pin outs. I installed the card and I can't get any more than 2 chanels to work but the good news is that the Asus adapter works fine when connected up to the appropriate pins.
    As these can be bought for a quid on ebay it offers a cheap way to get optical out of your card.
    If I ever get 7.1 working on the Co-ax I'll let you know if the Asus works too!
    Dave
  3. Razor
    Razor
    Dec 15, 2004
    37,547
    2
    +12,504
    I am having the same problem I have a coax connected via a mini jack adaptor (only 2 pole/mono) and I am only getting 2 channel sound. In the knowledge base on creatives web site it recommends to use a 4 pole mini jack adapter. I wil try this and report. It seems so silly that creative havent made it easy to connect to an amp in 5.1 digital. Has anyone connected their Audidgy 2 zs to a reciever using a coax?
    (I can sometimes get dolby prologic but not on all the time)
    Its driving me mad. Help would be appreciated.
  4. DaveP
    DaveP
    I have also just been searching through their knowledge base, but obviously a different part, as it said that it didn't matter which mini jack you used (stereo or mono) as the signal only passed through the tip. Besides, I get the same problem through my home made optical link! (true, it is unproven at the moment but my old sb Live! will be going back in tonight and I'll test it on that too)
    Dave
  5. DaveP
    DaveP
    I just got the following reply from Creative:
    I'm not convinced! I played a DTS and a DD5.1 movie with the configuration as they suggest and just got Pro Logic IIx. I'll have another go tonight
    Dave
  6. DaveP
    DaveP
    Well how can I put this?
    I did as they suggested and it works now when I play a DTS movie.
    TBH I did do two changes at once: I had already deleted the device from Device Manager and then let it re-install itself when I re-booted. And I'm sure that I had initially had the pass through set on and had only removed it in desperation when everything else I'd tried had failed to work.
    Some more good news came out of this. I swapped over to the Asus optical output and that works fine now too :clap: Whilst messing about with the cables I managed to disconnect the +5v wire from the board and lo and behold the optical signal carried on working!
    So you only need a two wire connection - I'm using an old CD digital wire that I used to use to connect my CD drive digitally to my original SB16 card (remember them?)
    This is the Asus converter here
    As you can see, it also gives a proper co-ax connection too.
    If anyone else wants to try this the pins to connect (on the Audigy) are pins 7 (Ground) and 9 (S/PDIF out). That's on the cluster of pins marked "SPDIF_IO"
    Dave
  7. Razor
    Razor
    Dec 15, 2004
    37,547
    2
    +12,504
    Thanks for the info. I could only get prologic on a limited number of divx films. This has now been solved but I am still only getting prologic and not 5.1
    I have enabled the spdif in audio hq/device controls/decoder. I then enabled the CMSS option in EAX console.
    I am using a mono minijack to phono connector with a good quality coax lead straight into my receiver (sony db930)
    The thx console has 5.1 and 48khz, when doing the channel test sound only comes out of the front three speakers with the rear channels coming out of the front left/right. :(
  8. PLASMATU
    PLASMATU
    Jul 31, 2004
    169
    here i have got an Audigy 4 with the optical out i jst can get Dolby Digital anyidea ? When i use DTS my ampli mutes....(means 0 sound ) m not the only one havin this issue thanks to anybody that can help me to fix that.
  9. Razor
    Razor
    Dec 15, 2004
    37,547
    2
    +12,504
    Are you decoding sound on your pc or passing through to your amp?
    Check in your AC3 filter.
