Audigy 2 ZS problems with VLC and Media Player
Discussion in 'Desktop & Laptop Computers Forum' started by phfjones, Jul 31, 2005.
  1. phfjones
    phfjones
    Mar 22, 2004
    99
    All,
    Can you help with this one?
    I have an Audigy 2 ZS Soundcard with an ATI Radeon 9800 Pro graphics card in a Dell 4600 Dimension HTPC.
    Problem I have is when my PC starts up the windows 'start up' music is there. However, if I try to play a file in Media Player or VLC the sound does not come out at all. I have seen DaveP's issue about SPDIF, but my problem is for all of the media players not just Media Player.
    Any ideas what I should be doing?
    Paul
  2. iZombine
    iZombine
    Jan 21, 2005
    870
    28
    +33
    Open up creative Speaker settings and make sure digital out isn't ticked as default.
  3. phfjones
    phfjones
    Mar 22, 2004
    99
    Thanks Reznor,
    Just did this and it was unchecked. I restarted the system. I'll try reinstallling and see how that goes.
    Any other suggestions welcome
    Frustrated!
    Paul
  4. iZombine
    iZombine
    Jan 21, 2005
    870
    28
    +33
    Any Luck?
  5. phfjones
    phfjones
    Mar 22, 2004
    99
    No. Turned out I was trying an optical digital cable instead of Coax from the 3.5mm jack!! A quick trip to Maplin fixed it!!
    Paul
