Audigy 2 and Decoder question?
Discussion in 'PC Gaming & Rigs' started by unrealrocks, Dec 2, 2003.
  1. unrealrocks
    unrealrocks
    Not quite sure where this should go but I'll stick it here ...
    I'm looking to buy a decoder (Denon AVR1603 prob) and want to check, I have a digital out on my Audigy 2 but its a small 3.5mm Jack ... will this work with the phono type Digital jack in on decoders?
  2. gingercat
    gingercat
    Nov 19, 2002
    490
    Lancashire, UK
    +27
    It'll work just fine, that's the connection I used to use for mine.
  3. Kramer
    Kramer
    Yep, you'll need a 3.5mm jack to phono adapter, available from Maplin etc. for < £1.
    :smoke:
