Audigy 2 > amp via digital out?
Discussion in 'Desktop & Laptop Computers Forum' started by garyc, Jul 31, 2005.
  1. garyc
    garyc
    Dec 21, 2002
    895
    Jersey, Channel Islands
    +14
    I have a audigy 2 sound card and want to output the 5.1 audio from the digital output jack to my external amp but the output jack is only a 3.5mm and the amp has an rca input.
    Any help on the cable I need?
    cheers
    Gary
  2. DaveP
    DaveP
    It's not a cable exactly. You need a minijack to female phono adapter.
    Dave
  3. phfjones
    phfjones
    Mar 22, 2004
    99
    DaveP,
    I have this card and I bought a 3.5mm jack to optical cable for #10.00.
    Having said that I have not got it working yet!
    I am putting a call into Creative tomorrow.
    Paul
  4. DaveP
    DaveP
    It doesn't do optical out, it's electrical co-ax!
    Dave
  5. phfjones
    phfjones
    Mar 22, 2004
    99
    Ah! 10.00 well spent then!
    Paul
  6. garyc
    garyc
    Dec 21, 2002
    895
    +14
    cheers guys
  7. 9761
    9761
    May 16, 2005
    536
    Electrical co-ax?
    Never heard of that, do you mean you get a phona to 3.5mm adapter and then use a digital coax cable from the adapter which is in the Audigy to the amp?
  8. DaveP
    DaveP
    I was trying to differentiate between optical and co-ax. Optical uses light and digital co-ax uses electricity. :lesson:
    Perhaps next time I should assume everyone knows what digital co-ax is.
    Dave
  9. 9761
    9761
    May 16, 2005
    536
  10. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    The above combo - min jack to phono then digital phono cable (75 ohm) work fine. I have this setup. Found a gold plated minijack to phono at maplin, then used an old video coax.
  11. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Yup, that works or use the left hand channel of a 3.5mm -> 2 phono like those used to connect personal stereos to a hifi. :)
  12. phfjones
    phfjones
    Mar 22, 2004
    99
    All,
    Me too. Went to Maplin and Hey Presto, all working!
    Great job all,
    Paul
