witwald
Established Member
The following conference paper by Soren Bech (Bang Olufsen a/s) may be of interest to users of subwoofers.
Søren Bech. Quantification of subwoofer requirements, part II: the influence of lower system cut-off frequency and slope and pass-band amplitude and group delay ripple. Preprint 5199, 109th Convention of the Audio Engineering Society, 2225 September 2000, Los Angeles, California, USA.
During testing, subjects evaluated the magnitude of Lower Bass and Upper Bass in relation to a fixed reference condition. The test signals consisted of different programme material, chosen to ensure that there was sufficient energy content at the frequencies of interest. The influence of filter order (2nd, 4th, and 6th) and lower cut-off frequency (20, 35, and 50 Hz) were studied. The influence of amplitude and delay ripple corresponding to four different reverberation times was also studied.
Interestingly, Bech's experiments utilised two reproduction methods: 1) a real loudspeaker in an anechoic chamber, and 2) a simulated system reproduced via headphones. The results showed that there were no significant differences between the data produced by these two methods of reproduction.
As might be expected, Bech found that the lower cut-off frequency has a significant influence on the perceived level of Lower Bass and Upper Bass reproduction, independent of reproduction levels. The effect of filter order was not found to be of significant importance. The amplitude ripple was also found to have a significant influence on the perceived level of Lower Bass and Upper Bass reproduction.
With regard to the audibility of amplitude ripple, Bech found that the threshold of audibility corresponded to a ripple of +3 dB relative to the reference transfer function. The threshold level was further found to be independent of reproduction level, whereas the influence of higher-amplitude ripples increased with increasing reproduction level. The audibility of the ripple also depended on the signal.
How do the above findings sit with the broad experiences of subwoofer users in this forum? Have people found that the low-frequency roll-off rate (e.g. 2nd-order for a closed box system, 4th-order for a vented box system, 6th-order for a filter-assisted vented box system) has little or no affect on the perceived quality of subwoofer bass reproduction?
