GavTNewbie
Established Member
On my Audi A3 3.2 Quattro S-Line (2005 05 registered, roughly at 93k miles now)... Ive recently heard a noise from the driver side rear wheel. Upon further inspection, Ive noticed what is best described as some sort of solid ring of carbon/concrete-appearing substance. The noise I hear occurs when I go over any sort of roadbump/sleeping policeman etc (as this part moves up and down the shock shaft).
Image of it:
My questions on this are;
It is important to note that the car still drives fine, and the balance of the car still appears fine (given the age of the car). Im just concerned this is not meant to happen, and may cause further damage down the line...
Image of it:
- is this dangerous ?
- is this expected over a lifetime of a shock ?
- will this have reduced the effectiveness of the shock/suspension ?
- should I get this immediately addressed ?
- if above is true, do i need to replace both rear shocks ?
