Audi A3 ICE
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by chrisambler, Oct 15, 2003.
  1. chrisambler
    chrisambler
    I have just got an Audi A3 1.8T and I am wanting to upgrade the factory fitted System to a decent sounding one.
    I have a few bits of kit already from my golf but the mid's won't fit the audi.
    I have
    Rockford 5x Amp
    Rockford 2X Sub Amp
    2x Diamond 10" subs
    Macrom 6" Mids
    JVC Sh909 CD/MP3 Headunit.
    Any Ideas???
    Cheers:)
  2. Dave20
    Dave20
    hmm.. tbh.. it depends on how much you wanna cut the audi about.. and how much money you wanna spend obviously your used to nice sound with punchy bass..
    imo, throw the jvc away and buy a nice alpine. keep the amps and subs and buy a new set of mids and tweets which will fit in the front.. or go to a specialist dealer and get them to install some kickpanel builds for the macroms.. ( i got some nice Diamond componants to match those subs) ;)
  3. woosey
    woosey
    :rolleyes:
    have you heard the JVC? i competed in IASCA using the JVC 909r, very nice peice of equipement for the price! I have now got a 7969 (4th best alpine ever made) and its far to harsh!
  4. woosey
    woosey
    right as for you :p
    what box are the diamonds in? What sort of sound are you after? Perhaps look at new component set for your audi with a budget, if you want more speicalied ICE help pop over to www.talkaudio.co.uk (ICE forum, im a member there too :D)
    Also forgot to add!!
    have you sound deadend your car? if not this is a MUST if your going to get the most out of the sound
  5. Dave20
    Dave20
    sorry dont do jvc.. ever.. spent 7 years with almost all brands of head unit day in and day out.. top spec alpines all the way for me. i must admit the old pioneer bluechip sets were up with them though
  6. danny-p
    danny-p
    What do you mean by this, how do you do it and how much does it cost?
    Danny
  7. Dave20
    Dave20
    its basically to pad out your car to stop panels vibrating, sound leaking and road noise coming in. i spent £300 on sound deadening material alone for my subaru. that was trade price as well heh. i coulda spent alot more. but you can spend alot less, depending on how rattle'y your car is.. but you would have to obviously put labour charges on top of that..
    it is a must if you want every little bit out of your system and want to compete in competitions. but for someone who wants a nice bassline without spending lots of cash then it isnt worth the amount of money it would cost imo.
  8. chrisambler
    chrisambler
    sound deadening is good stuff....
    I had a load of it in my old Golf Mk4 and it sounded Ace... shame some fool decided to loose control of his car and write mine off....
    Thats why I have the Audi now and all the questions... Cheers for your replys...
    As for the JVC remarks... I got the JVC because I couldn't get an Alpine at the time... I really wanted one as well but no one could get hold of the unit I was after....
    So The dealer ended up doing me a JVC to see if i was happy with that...
    And the unit was pretty good... I've had a alot of problems with Reliability though... its been back 4 times...
  9. woosey
    woosey
    What model JVC is it mate? I have had the 99r and 909r without problems
    Chris
  10. chrisambler
    chrisambler
    Mine was the sh77 and that went back twice eventually they swapped it for a 909r which was ok before the car crash...
    not sure it'll still work because it was playing a cd at the time of the impact..
    oh well we'll see next week when i get my kit back....
