AU7100 wall mount screws problem
Cuke
Joined
Jun 2, 2022
Messages
Reaction score
Points
26
Age
46
Location
Gloucester, UK
Hello, sorry in advance if I’m being thick… I have a new Samsung AU7100 and a VESA wall mount with M8 screws… however, the screws in the kit that are long enough to go in the holes on the back of the TV appear too narrow/thin and just spin in the holes… there seems to be very little info online about Samsung needing non standard screws and the TV manual just says M8 screws (which these are…) so I can’t really see where I’m going wrong… does anyone have any ideas?
Are you sure you have M8 bolts ?
I have an AU9000 and the holes are definitely M8 but the VESA mount I was using from my previous tv install used M6 bolts so I had to drill the holes out and find some M8 bolts
Is Home Theater DEAD in 2024?
Back
