Question ATX based HTPC Upgrade
Discussion in 'Home Entertainment Computers' started by icstm, Jul 23, 2018.
  1. icstm
    icstm
    Sep 24, 2007
    1,212
    +66
    As you can see from my build log, my current hardware is a little dated and would love the forum to suggest upgrade options!
    Not sure of budget, but generally I have gone mainstream enthusiast type components. Happy to take a different steer based on your inputs.
    I would like to update the following:
    • Processor (from i5 2500k)
    • Motherboard (Asus P8P67 Pro)
    • Graphic Card (if needed, I understand the processors are much better now with true 23.976 support and HDR future proofing
    I Will keep
    • Case and PSU (Fractal R3)
    • SSD with current build of OS and apps (Evo 840 I think)
    • HDD (multiple internal)
    • seperate external SATA box (StarTech) so motherboard required to support port multiplier for eSATA
    I Will need to replace
    • 16Gb RAM (might not need that much)
    New items:
    • non black colour wireless keyboard, not too big or noisy, but good to typing
    Thoughts please!
  2. icstm
    icstm
    Sep 24, 2007
    1,212
    +66
    The Mobo should have Coax audio output and either it on GFX should have HDMI (obvs).
    If the Mobo has Bluetooth, bonus, but I have a dongle if required.
    I should add key uses:
    • Media server (Plex, JRiver)
    • Media Player - please spec for MadVR
    • Photo / video editor
    • Work (semi large spreadsheets and the like)
  3. icstm
    icstm
    Sep 24, 2007
    1,212
    +66
    any thoughts on the above? esp if i can get away with just a cpu these days?
  4. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,398
    +1,304
    Just buy a new gpu?
  5. icstm
    icstm
    Sep 24, 2007
    1,212
    +66
    @ChuckMountain thanks for you reply.
    Why a GPU? you mean one that supports CUDA? or are there now AMD (ATI) cards that can accelerate MadVR processing of video?
    I was thinking a little CPU boost could work and thus I was wondering which of them work well with MadVR directly without a GPU. I understand their own graphics ability now correctly supports 24p, HDR, etc
  6. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,398
    +1,304
    You didn't mention what gpu you had before or whether you just used built in one.
    I just wondered whether you could get away with a low end passive Nvidia GPU.
    Processor is not bad for your requirements and just wondering if replacing MB and cpu you are spending more than you need to?
