ATTN Sony NWHD5 users
Discussion in 'Headphones, Earphones & Portable Music' started by wilto, May 22, 2005.
  1. wilto
    wilto
    Apr 23, 2005
    309
    Cardiff
    I got my player on friday...lovely piece of hardware isnt it!
    Just asking a query if any of you can get the automatic screen rotate function to work.
    I was led to believe that the screen would rotate automatically depending on which way it physically is!
  2. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,464
    +6,239
    don't tell me Sony have given you a dodgy one.
  3. wilto
    wilto
    Apr 23, 2005
    309
    Cardiff
    lol lets hope not...
    if they have ...its been very traumatic for me and i deserve compensation and free stuff off Sony.
  4. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    Erm, I think I read somewhere that it doesn't rotate automatically. The screen will be the right way up when you switch it on, but wont rotate as you turn the player. Basically it stays the same way (in relation to the player) as it was when switched on. But it won't rotate accordingly as the player is rotated.
  5. wilto
    wilto
    Apr 23, 2005
    309
    Cardiff
    ah ok....thanks mcfarfs.
  6. snownrock
    snownrock
    May 22, 2005
    34
    yes the screen is controlled by the g-sensor, it only stays in the direction that which it was switched on.
  7. Hrochnick
    Hrochnick
    Apr 28, 2005
    369
    Brno
    +9
    I find it slightly annoying though and was suprised when I first switched mine on - All of Sony's advertising suggests that it moves as you turn the player "flipping from horiszontal to vertical with your every move"... I don't think so. False advertising?
  8. wilto
    wilto
    Apr 23, 2005
    309
    Cardiff
    yup this is what i thought too.
  9. Fencer02
    Fencer02
    There are now a number of threads with people who are more than a little fed up with our friends at Sony, misleading or using "Spun " advertising. I too thought the HD5 display revolves with movement and whilst technicaly it does the truth is not quite the truth is it. Also we have HD3 having 30 hour battery life , again it probably does in the Lab not however in the real world. I will not get in to the morality of solving problems by issuing new models instead of addressing firm ware issues on the old ones. And now we have a product recall to add insult to injury..............
    To gain an understanding of the ethos that obviously still exists at Sony a small story will illustrate fully how they think and how deep rooted this is.
    One of the first Sony products was a Transistor Radio produced I think in the late 50's or early 60's. It was advertised as a Radio that would fit inside your shirt pocket, and indeed that was a major selling point that the thing was small enough to fit in a shirt breast pocket. All the salesmen duly went round the customers selling the shirt pocket radio..............Only problem was it didnt fit a standard shirt pocket. It did however fit the "Special shirts with enlarged shirt pockets that Sony had made for their salesmen.
    I remember seeing this on a documetary and the Sony executive was very proud of this piece of duplicity................Leopards and spots come to mind
    Go here for support of this story
    http://www.uefap.co.uk/reading/exercise/texts/sony.htm
    This story is repeated from " Made in Japan by Akio Morita"
  10. wilto
    wilto
    Apr 23, 2005
    309
    Cardiff
    yeah.
    im not too bothered about this particular feature but it was advertised quite a lot and to think its not what they made most people think it to be - is pretty bad!
  11. KeanosMagicHat
    KeanosMagicHat
    Feb 7, 2005
    4,551
    England, UK.
    +554
    With regard to the "follow turn" feature watch the movie at the startup of this web page ...... even it is misleading as it appears to show the screen changing orientation.
    http://www.sony.co.uk/PageView.do?s...23732458&section=en_GB_Magazine_Entertainment
    EDIT - it gets worse, and implies that early units may be faulty as when you click "Design" and then "Follow turn" it definitely shows in graphic form the screen actively changing orientation "The screen is synchronised to your hand movements flipping from horizontal to vertical with your every move".
  12. whiteairzuit
    whiteairzuit
    May 23, 2005
    14
    I totally agree, you can clearly see that when the hd5 is moved horizontally across the screen the image is horizontal then a quick bit of shifty computer graphics later, the screen has magically turned vertically without being turned off and on again
    Apart from that little point and an annoyinjg volume limiter which can be turned off by a sequence of key presses, I am one happy HD5 owner.
  13. KeanosMagicHat
    KeanosMagicHat
    Feb 7, 2005
    4,551
    England, UK.
    +554
    whilst you're on try clicking "Design" and then "Follow turn", the graphic displayed shows the same thing.
    I'm beginning to wonder if the early units have a fault here?
  14. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    You are right. I think somebody needs to email Sony, linking them to that URL and ask them what the **** is going on. Either early units are indeed faulty (seems unlikely to me), or Sony are REALLY taking the mick here.
  15. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
  16. Hrochnick
    Hrochnick
    Apr 28, 2005
    369
    Brno
    +9
    I've got a feeling, though I can't confirm at the mo cos I'm at work - that the manual describes the operation of it as it actually works (i.e. they are not broken), in which case it's definitely misrepresentation.
  17. watchinthewheel
    watchinthewheel
    i cant believe sony have done that! thats really blatant missleading advertising, i reckon they could be sued over that no problem. im very glad i didnt shell out another £200 on a hd5 to upgrade from a hd3 its not worth it at all by the looks of it.
  18. KeanosMagicHat
    KeanosMagicHat
    Feb 7, 2005
    4,551
    England, UK.
    +554
  19. Hrochnick
    Hrochnick
    Apr 28, 2005
    369
    Brno
    +9
    I've just double checked the manual and it does indeed state 'when you turn the player on'.
  20. ohms
    ohms
    Apr 27, 2005
    55
    9
    yeah if they are lying....that just isnt on. blatant misadvertising. not tricks. thats just shoddy.
  21. wilto
    wilto
    Apr 23, 2005
    309
    Cardiff
    blatant lieing!
    ah well i love my sony hd5!
    my battery came full charged and on my first charge up i have to say it hasnt lasted any where near 20 hours let alone 40 hours.lets hope this improves.
  22. watchinthewheel
    watchinthewheel
    the 40 hour mark is under lab conitions, with everyhting turned off, backlight shuffle etc. i reckon if you play a single mp3 over and over without any movement of the player it would reach the 40 hour mark. you will never get it in the real world. the screen rotate thing is a joke though, i would complain to sony if i had bought a hd5
  23. wilto
    wilto
    Apr 23, 2005
    309
    Cardiff
    yeah im going to write a letter/email to sony stating with all the appropriate links and explanations as to whats stated to happen and what is actually happening.
  24. KeanosMagicHat
    KeanosMagicHat
    Feb 7, 2005
    4,551
    England, UK.
    +554
    Not necessarily so.
    I have an NW-HD1 at the moment and it was advertised as a maximum of 30 hours on ATRAC 3plus 48.
    I have my music stored at ATRAC 3plus 64 and a remote attached and decided to do a test. I was pretty impressed to get 28.5 hours.
    As for the complaint I hope someone does it because, as someone who's not going to take delivery of an NW-HD5H for another couple of weeks I'm kinda hoping it's a fault with the early models (subject to an imminent recall obviously).
  25. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    Now I think about it, if we complain to Sony I reckon we will just get a stupid PR response.
    I suggest HD5 owners contact Trading Standards, making an official complaint. Link them to that preview on the Sony site, this thread etc. and explain exactly how you feel about the problem.
    www.tradingstandards.gov.uk
    If you are from outside the UK, email your country's equivalent!
  26. Cloysterpeteuk
    Cloysterpeteuk
    Feb 5, 2005
    4,392
    Whitby, North Yorkshire
    +892
    Does the HD5 now support AAC?, seeing as the Sony Ericsson mobiles have supported it for ages.
  27. Hasselhoffia
    Hasselhoffia
  28. caaralagueva
    caaralagueva
    I bought a silver NW-HD5 last Friday from my local Sony centre and have been following this thread ever since, noticing people's disilusion in Sony's advertising techniques.
    I wrote to Sony expressing my 'disappointment' that the NW-HD5's screen does not rotate in real-time as implied by their advertising, but only when the unit is powered on and this is their reply:
    Dear Miss Lamb
    Thank you for your recent enquiry.
    It was not our intention to mislead anyone and the info was meant to relay that
    the screen would appear horizontally or vertically depending on how you prefer
    to use it. Clearly it does do this though only when powered on and not for when
    you want to rotate the unit whilst in use. We are sorry if this is not what you
    expected but again, it was not our intention to mislead. We do believe this is a
    high quality unit and hope that you will get years of enjoyment from it.
    I hope this information is of assistance.
    Finally, if you need to reply to this e-mail, please quote reference XXXXXXXXX
    in the subject field of your e-mail.
    With Regards
    [mod comment - do not use the names os Sony employees]
    For and on behalf of
    Sony United Kingdom Limited
    Not a great reply.. but there's not really much else I can say to them.
    Has anyone else had a reply from Sony re this issue?
  29. wilto
    wilto
    Apr 23, 2005
    309
    Cardiff
    i wrote a rather stern letter with the help of my grandfather whos a solicitor, he took a look and he said if he was the owner he would be outraged at this lieing false advertising!
    but he said dont expect anything off sony, they will say sorry, change the advertising and we will never hear of this again.
  30. KeanosMagicHat
    KeanosMagicHat
    Feb 7, 2005
    4,551
    England, UK.
    +554
    At least if they change the advertising that is a start.
    It's plain wrong to advertise this "feature" in the way that they have.
