Attenuators and signal degredation
Discussion in 'Hi-Fi Stereo Systems & Separates' started by sounddog, Jan 18, 2003.
  1. sounddog
    sounddog
    Dec 11, 2002
    3,445
    107
    Leicestershire, UK
    +480
    I've got a Rotel RA1060 and Arcam DV88 which I'm using for CDs via it's analogue output.
    My problem is that at the levels I want to listen at usually, the volume on the Rotel is so low that I have little or no fine control over the level ... it seams that when I'm using other sources (front channels of my AV amp) and the control is nearer the 12 o'clock position there is a lot finer control avaliable.
    I've been considering buying a pair of in-line attenuators (either 9dB or 12dB) from Keene Electronics but if I use these ... will they (dramatically) degrade the signal (other than lowering it which is of course the whole aim)?
    Any experience of these (or recomendations of other sources of similar attenuators) would be greatfully recieved.
    Victoria
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Rockwell make the best attenuator I know
    Russ Andrews do Kimber cable with these built in
    I didn't know Keene did these, make sure they are not aerial attenuators ;)
  3. alexs2
    alexs2
    Nov 13, 2002
    13,967
    +1,671
    The best attenuator I've ever found(and I do have one)is the Audio Synthesis Passion...it's a stepped attenuator,basically a passive pre-amp,using Vishay resistors.
    In my own experience and that of any reviewer who's used it,it's as good as most £5k plus active preamps...but it does cost £500,so most will choke on the cost....some are available secondhand.
    I use mine sometimes to run CD straight into the power amps and bypass my Tag.....it does sound better,but a bit of a pain with the wires!:cool:
  4. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Did know we were talking pre amps here :blush:
    As another Audio Synthesis passive pre amp owner I can vouch for their exceptional quality, don't like high C cables though
  5. alexs2
    alexs2
    Nov 13, 2002
    13,967
    +1,671
    Absolutely true,Beekeeper,but since the topic was attenuators.....well close enough anyway,and also agree with what you say about high C cables.....use Kimber and XLO here.
    The Passion would also leave most preamps for dead on sound quality,especially when you use it to bypass the active pre and run the CD straight into the power amps.:cool:
  6. sounddog
    sounddog
    Dec 11, 2002
    3,445
    107
    Leicestershire, UK
    +480
    No ... the Keene ones arn't aerial attenuators ... definately audio ones.
    Sorry if this is a daft question ... but who is Russ Andrews?
    Victoria
  7. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    controversial but has some GREAT kit inc Kimber cables.
    His basic stuff is the best IMHO
    www.russandrews.com
  8. alexs2
    alexs2
    Nov 13, 2002
    13,967
    +1,671
    Also use Kimber here,Beekeeper,and agree his cheap stuff is the best value,but the more expensive stuff has amazing sound quality.
  9. GaryG
    GaryG
    Nov 20, 2002
    754
    Shropshire
    I'm so pleased you posted this, you are likely to see it crop up from time-to-time as I quote you to the people who think Tag is the 'be-all-and-end-all' of all things AV. Maybe Ferrari should start making AV gear and give them a walloping at that as well.:D
  10. alexs2
    alexs2
    Nov 13, 2002
    13,967
    +1,671
    Thanks Gary!....as you can see,I do have an AV32R and I am very pleased with it.
    The thing is that the Tag is designed to one job(AV processing)and does it very well indeed....the AS passive preamp is designed to do another,and does so with amazing clarity...at least the equal of £5k plus active preamps(and not AV preamps here)....it's just like stripping away layers of masking due to digital processing...what you put into it,comes out,just attenuated to the level you want.
    The only problem comes with long cable runs,or a CD player/DAC with weedy output stages...if you have either(or both) of these,the results wont be too hot.
  11. GaryG
    GaryG
    Nov 20, 2002
    754
    Shropshire
    Couldn't agree more. Unfortunatley the TAG brand has reached 'cult' status and is assumed to be great at everything, which clearly it is not, I'm not knocking Tag by the way.
  12. alexs2
    alexs2
    Nov 13, 2002
    13,967
    +1,671
    Again,I agree,Gary......cult staus is all very well,but it doesn't mean a piece of equipment does everything equally well....bit like the status of Lexicon and others as well.....bet that will get a few people going also! :p
