attenuated interconnects ??
Discussion in 'Hi-Fi Stereo Systems & Separates' started by jonnyv, Apr 21, 2003.
  1. jonnyv
    jonnyv
    Mar 31, 2002
    2,143
    48
    +41
    I am looking for a replacement lead to hook up my dvd player to my amp, its a 2 phono analogue lead, i use this for listening to cd's only.
    Ive seen an article about attenuated interconnects that reduce the output signal so as not to overload the amp.
    details here : http://www.russandrews.com/download/wired_for_sound.pdf
    My amp outputs a 2.0v (rms) signal, my receiver is rated at 335mv, using the table in the wired for sound pdf file, i need a -11db cable.
    I have been offered a -16/-14db cable for a good price.
    So my questions are: Do you agree with the attenuated cable idea ?
    Would the -16/-14db cable be ok for my system ?
    thanks
  2. sounddog
    sounddog
    Dec 11, 2002
    3,353
    107
    Leicestershire, UK
    +449
    What DVD player?
  3. jonnyv
    jonnyv
    Mar 31, 2002
    2,143
    48
    +41
    Its a toshiba sd-900e.
  4. nathan_silly
    nathan_silly
    I've never had problems with CD player analogue outputs overloading the amp, have you SD?
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    with older amps it can be an issue, especially pre CD era
  6. mick23
    mick23
    Mar 20, 2002
    801
    uk
    i have the ra tonic 14db rca lead with nad541+3802,the way i understand what the lead is meant to do is thus,
    if having your amp playing at a high volume that is TOO loud to be happy with, the attenuated lead allows you to use more of the amps power but not be TOO loud it cuts the volume by 14db,
    having tried the tonic i cannot really be sure myself if i am getting that much of an advantage, over normal i/c if you wish to try r.a gives you a trial period anyway ,
  7. jonnyv
    jonnyv
    Mar 31, 2002
    2,143
    48
    +41
    Thanks for the reply mick, ive sent you a pm
  8. Sunday Ironfoot
    Sunday Ironfoot
    So basically it lowers the volume coming out of your CD player? My Marantz has a volume control for the phono outs anyway.
