Attention Toshiba 32WL56 owners
Discussion in 'LCD & LED LCD TVs Forum' started by ViolentReaction, Aug 13, 2005.
Tags:
  1. ViolentReaction
    ViolentReaction
    Jul 21, 2005
    1,464
    +226
    Hi all,
    Im sorry if I've posted in a few threads regarding info on this TV, but I am now looking at it as a serious alternative to the Samsung LE32R41B (due to the tearing issue).
    I have two main questions :
    1) Do anyone know what the response time is? Has anyone got the Xbox / PS2 hooked up to it, and if so have you seen any ghosting? I believe the Sammy has a response time of 12ms.
    2) Has anyone in the UK soft modded their Xbox to output in 480p (or 720p for some games) using the high definition offical cables? If so how did you do it, as the lead is component and their is no component input into the Tosh.
    Thanks all!!
  2. HHGTTG
    HHGTTG
    Aug 1, 2005
    869
    South London
    +65
    8ms I sure I read somewhere, but I could be wrong as I've read so much bumf on LCD's recently
  3. MADMAND
    MADMAND
    Aug 4, 2005
    356
    +8
    1. I think the response is 10ms
    2. Your gonna need an amp/switchbox with 2x component in and 1x out or you could just wait for 360.
  4. ViolentReaction
    ViolentReaction
    Jul 21, 2005
    1,464
    +226
  5. tulloch2003
    tulloch2003
    Mar 21, 2003
    898
    Port Talbot
    +16
    Hi what conecters come from the xbox then. I have use this cable with a Samsung HD950 on a 32WL56 LCD. Was working fine @ 1080i on the VGA on the Tosh and component from HD950.
    Regards Tulloch
  6. ViolentReaction
    ViolentReaction
    Jul 21, 2005
    1,464
    +226
  7. MADMAND
    MADMAND
    Aug 4, 2005
    356
    +8
  8. tulloch2003
    tulloch2003
    Mar 21, 2003
    898
    Port Talbot
    +16
    @ ViolentReaction the lead that I give you a link should work yes or no. The Tosh will do all the settings on the VGA socket, you mention with a dvd player. So should be ok with the xbox.
    Regards Tulloch
  9. supermackem
    supermackem
    Feb 20, 2005
    2,151
    sunderland
    +78
    Yep i bought what was an expensive JS tech master component switch and used a yuv to vga lead and a ixos compoent xbox lead. Works a treat and looks amazing all the way to 1080i.
