Attention All PV500 Owners
Discussion in 'Plasma TVs Forum' started by londonr, May 2, 2007.
  1. londonr
    londonr
    Jan 31, 2006
    109
    16
    Wexford
    I have been told that you can not accurately adjust the contrast on a PV500 using a number of calibration disks (get grey for one). Using the user menu
    2 questions; Have any of you noticed that your contrast (white balance, brightness, white saturation whatever you want to call it). Seems a little too bright for your liking (no matter how much you adjust the contrast and brightness , Normal, warm settings etc)
    Does any one know how to lower the contrast (not user menu, I have tried a million times)
    This is on all sources, sky HD, DVD, using Scart or HDMI or Component, makes no diff, white balance is still off!:lease:
  2. Mr Eddy
    Mr Eddy
    Feb 26, 2005
    220
    Same here, anyone help?
  3. londonr
    londonr
    Jan 31, 2006
    109
    16
    Wexford
    Eddy, I had a calibrator come in and adjust my set - To be honest I don't think it is any better. I am begining to wonder if it is just my eyes. I just came back off 2 weeks hols, and to be honest the picture looks great - I think the more you look, the more you find wrong!
  4. punkymunky
    punkymunky
    Jan 16, 2007
    610
    46
    +170
    Mines fine, if anything could be brighter when the sun is shining
    You are right though, always looks amazing when you've been away from home for a while - particularly when you stay in hotels with LCDs stuck on the walls ;)
    It's the same everytime I wheel the motorbike out of the garage in spring, fabulous for the first few rides then... could do with a bit more power, an extra gear, think there's a flat spot at 5000rpm etc etc
