attention all infocus 7200 owners/future buyers
Discussion in 'Projectors, Screens & Video Processors' started by peter123, Jan 7, 2005.
  1. peter123
    peter123
    unless you can sort of the fan noise problem i would not recommend any infocus one chip porjectors....
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,150
    UK.
    +2,670
    One of the best solutions I've seen is to have the pj in the room behind you projecting through a hole in the wall - just like a real cinema!
    RTFM had that set-up for one of his Sim2 projectors, and I think it's one of the best ideas - providing you have the room etc though. A well ventilated cupboard could work I suppose.
    Gary.
  3. oaklandraiders
    oaklandraiders
    Aug 2, 2002
    1,237
    Surrey
    +47
    Yo
    Steady on !
    You must have sensitive Steve Austin bionic ears, its not that loud.
    Are you running in low power bulb mode ?
    Currently mine is low down at head level, right next to me (well left) and its not annoying when watching a film.
    Its noisier than previous Z1 but you get used to it.
    Soon it'll be up on the ceiling where I'm I'm sure I wont hear it.
    John
  4. peter123
    peter123
    well yes its very close to me the fan noise is not the most annoying thing but the vibration is! it tens to vibrate so much that it creates heavy noise
    any anti vibration desk or something i can use?
  5. daredevill
    daredevill
    Jan 8, 2005
    501
    46
    +156
    I had the screenplay 4800 model and now have this the 7200 and even in high power mode the noise is only just louder than the other model I had.
    When the film starts you dont even notice the fan noise, are you Sure you didnt get a bad one ?
  6. peter123
    peter123
    maybe i was ripped off on the fan noise issue
    can i return it to toshiba for fixing?
    thx
  7. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,684
    Woking
    +230
    I would definately check what lamp mode yours in set to. My Infocus 4805 in high lamp mode makes an awful din but in low lamp mode, I barely hear a thing !
  8. peter123
    peter123
    well high mode is not turned on so i guess its low mode?
  9. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,684
    Woking
    +230
    Definately get it checked out then ! Sounds wrong to me .
  10. peter123
    peter123
    what should i do call toshiba or what? i hope the manufactureres warranty provides the costs i dont want to spend any further money
  11. martian1
    martian1
    Dec 30, 2001
    2,395
    113
    Sunderland
    +638
    Hang on peter i thought you said you had the infocus 7200...whats all this toshiba talk? :eek: What model do you have exactly for £1500.
    The noise could be a duff colour wheel :mad: or as with my old pc graphics card a faulty fan, this caused an awful noise and bad vibration...it was catching on a loose cable while spinning. I may be wrong but the INFOCUS 7200 has a lamp unit that comes with a fan attached ..check it out. Good luck.. oh could you pm me if possible with that 7200 retailer you hinted at :smashin:
  12. peter123
    peter123
    well its a toshiba MT8 wich is pratically the same as 7200
  13. martian1
    martian1
    Dec 30, 2001
    2,395
    113
    Sunderland
    +638
    Hummm..mybe not quite the same !
  14. peter123
    peter123
    its exakly the same unit mate!
    same spefications and same look
    only diffrens is the colour
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    doesnt mean the fans are the same................ seen clones before where corners were cut on some models cheaper Fans and cheaper casings just because the guts are same dont mean the ancillary bits are.......
  16. martian1
    martian1
    Dec 30, 2001
    2,395
    113
    Sunderland
    +638
    You are confusing.. :confused: you posted the 7200 from ebay [private deal] then state you have a m8 :eek: whats going on ! could be a lemon :clown: Contact Toshiba and get it checked..good luck!
  17. peter123
    peter123
    guess what martian1? ive just swapped my mt8 for a 7205
    how? well the one i swapped with had 100 hours left on the 7205 lamp only
    my mt 8 had 2980 hours left on the lamp!
    so all i have to do now is buy a new lamp and im set!
    i think 7205 should be much better
  18. Peter Baker
    Peter Baker
    Sep 6, 2003
    656
    28
    LONDON
    +37
    Are you sure it's a 7205? This model has only been out a couple of months so 2900 hours use sounds pretty unlikely!
    More likely to be the 7200 in my opinion.
  19. peter123
    peter123
    no mate im pretty sure its 7205
    by the way screenplay 7210 has been announced by infocus and will be out in 2-3 months! it will have the new darkchip 3 but the retail price will be very high!
  20. daz143
    daz143
    Is there a manufacture date on the bottom? if there is and its less than 2 years old, you can get warrenty work free by steljes.co.uk. They do all the warrenty work for Tosh UK.
    services@steljes.co.uk
    Also you can ring Toshiba on 01932 841600 and ask for the "PVP dept". The lady is called Julie Lions (or similar). The bad news is that, if like me, your MT8 only has the serial number - they dont seem to be able to find out when it was made.
