Attaching computer or laptop to Sagem Axium HD-D50
Discussion in 'General TV Discussions Forum' started by karan_thakkar, Oct 27, 2005.
  1. karan_thakkar
    karan_thakkar
    Does any1 know how to attach your comp or laptop to Sagem Axium HD-D50? I got a vga cable I attached it to my laptop and tried it with my comp but it comes out as a black screen sometimes blue flickering. Some1 suggested that it was about the refresh rate.
    Laptop graphics card: ATI Mobility RADEON X600
    Desktop graphics card: NVIDIA GeForce2 MX 400
    What is wrong what can I do and how?
    :lease:
  2. Snap
    Snap
    Aug 7, 2005
    188
    Celle (Hannover)
    firstly activate the VGA out. then set the resolution 1280x720 if possible and 60Hz. that should be fine.
  3. karan_thakkar
    karan_thakkar
    yup yup i have tried that res. and that rate problem will not go away
  4. sprattgraham
    sprattgraham
    Dec 10, 2004
    928
    28
    Hertfordshire UK
    +28
    I use to have the HD-D50,
    In the Install menu there should be something called "PC DATA" See if Auto Image is turned on if it is then try it with it tuned off. You can also give 1280x720 50Hz however make sure you are using 1280x720 and not 1280x768 If I remember that one does not work
    Can you get any resolution to work? If not I would think TV or Cable Problem
  5. dunsters
    dunsters
    Mar 14, 2005
    303
    +7
  6. karan_thakkar
    karan_thakkar
    ya will try thanx and will let u know in a week coz i am going ona holiday
  7. karan_thakkar
    karan_thakkar
    :lease: :thumbsdow :( :rolleyes: :nono: :confused:
    mmmmm i still gives same problems i tried it with diffrent settings too
