Attaching 32PF9986 to the wall
Discussion in 'LCD & LED LCD TVs Forum' started by jonf, Oct 21, 2004.
Tags:
  1. jonf
    jonf
    Sep 12, 2004
    240
    I have a 32PF9986. Really like it! Thing is I want to attach it to the wall. It comes with the wall bracket but no fixing screws. Has anyone fastened it to the wall? What length screws, rawl plugs are needed? I have a brick wall victorian terrace house - so not some modern built hollow wall place to contend with!
    advice please!!
    JF
  2. Howbury
    Howbury
    May 29, 2004
    41
    JF
    I have a similar house. I toyed with various special wall-fixing bolts but they were all too big for the holes in the support. I ended up using six (rather than 4) standard 3inch No 10 screws & rawplugs.
    John
  3. daveb975
    daveb975
    Oct 25, 2002
    4,251
    103
    London
    +347
    I did the exact same thing with my Plasma. I went out and bought some huge bolts, and then decided I would have it done professionally. I was surprised to see that the installer used very thin screws, about three inches in length with standard rawlplugs.
    Almost a year later and the plasma is still in place.
    My wall is the party wall between two large Victorian semis. The wall is very thick, but construction is probably much the same as yours.
    I am about to hang an LCD in my bedroom. I will take it on myself this time, using the same method!
