ATT Message
sjon
Hello All,
I pushed by mistake some buttons on the remote(i don't know wich ones)
of my AV32 DP and the message ATT instead of VOL appeared.
And now when i start up my av32 it also first shows ATT instead of VOL.
After changing the volume it is gone, can someone pease tell wat this is and how i do get rid of it?
Thanks for all your help.
Greetings
Miron
you've probably hit attenuation key
RTFM and it will be all clear
alexs2
On the DP,if you set it up like that,one press on the Mute key attenuates by x dB,and two mutes it fully....quite a useful idea.
Trending threads
Trending threads
