ATSC tuner ?
Discussion in 'Plasma TVs' started by anders260, Jan 9, 2004.
  1. anders260
    anders260
    What is this do the european modells have this ( Pioneer 434)?
  2. Dutch
    Dutch
    Dec 5, 2002
    2,594
    3
    North Yorkshire
    +281
    anders,
    ATSC is the High Definition TV standard used in the US. The ATSC tuner fitted in the US media box is for terrestrial HD broadcasts and so isn't fitted in the European box. Hope this helps.
    Steve
  3. anders260
    anders260
    thanks Dutch
    BTW are you happy with your 433mxe
  4. Dutch
    Dutch
    Dec 5, 2002
    2,594
    3
    North Yorkshire
    +281
    Very happy, thanks. Only wish I could have afforded the 50 incher. :smoke: The 4th gen MXE models should be out in the summer if you're interested.
    Steve
  5. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,126
    Manchester
    +714
    Dutch is correct.
    ATSC stands for Advanced Television Standards Committee
    and uses 8VSB modulation whereas our Freeview (and other digital terrestrial TV being rolled out in Europe) uses COFDM
    and is called DVB-T.
    Chris Muriel, Manchester.
