mikecahill
Can anyone advise which size Shure black foam tips (PA910's) I should buy to use with my Atrio M5's? I know this is a personal choice but as a guide I currently use the small foamies that come with the Atrios (but actually think a medium in those tips would be ideal for me but these are not supplied).
Having only seen the Shures on the net, I have no idea what size they actually are and I don't want to waste £15 on a set of them only to find they don't fit properly.
Alternatively, does anyone have any unused Shure PA910's of any size that you don't need - I'll happily give you a few quid for a pair.
Thanks,
Mike
Thanks,
Mike
