atrac3plus 256kbps vs mp3 alt-preset fast standard comparison?
Discussion in 'Headphones, Earphones & Portable Music' started by Stuart P, Jun 22, 2005.
  1. Stuart P
    Stuart P
    Apr 16, 2005
    2,115
    +172
    if i'm honest, i'm struggling to tell the difference between tracks ripped at atrac3plus 256kbps & mp3 alt-preset-fast-standard (i'm listening thru a hd5 using etymotic 6i's to listen with).
    should there be a difference in sound quality? or are the differences so very small, they are indistinguishable?
