atrac conversion crashes WHY!
Discussion in 'Headphones, Earphones & Portable Music' started by watchinthewheel, Jun 21, 2005.
  1. watchinthewheel
    watchinthewheel
    god i hate sonys programing dept!
    i am trying to convert a large number of mp3s at 320kbps (fine on a large hdd in my pc but not on my hd3!) into 225kb/s atrac so i dont lose too much quality, i have tried using ss and also using the seperate atrac converter you can download, both crash every 20 or so tracks, its a real pain! has anyone tried them and got em to work properly? if anyone is having trouble can you tell what the problem is, is the program just appauling and designed to crash or is it something with my pc setup? im going to try using another pc on my network i hope it will be a bit better but i aint holding out much hope.
  2. Kano
    Kano
    I had the same problem. I tried about 10 different albums i had on my hard drive. I even fresh ripped a cd to mp3 then tried to convert to attrac, with no luck.
    I gave up and just dumped them onto the player.
  3. watchinthewheel
    watchinthewheel
    ^bump^ can anyone offer help on this one?
