ATON AH66T-KT 6 Zone kit cheaper alternative?
Discussion in 'AV Receivers & Amplifiers' started by adamroutley, Feb 6, 2014.
  1. adamroutley
    adamroutley
    Aug 13, 2013
    57
    11
    Wolverhampton
    +11
    Hi guys, recently found exactly what I am after with regards to multi-zone, multi-audio, home audio system.
    Can pick one up from the states for about £1400.
    Does anybody know of a similar kit but for cheaper? I don't mind saving but if I can get a cheaper alternative then I will.
    Thanks,
    Ad
  2. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,439
    An explanation of the system you are planning and sources etc. you wish to use may help. Do you really need 6 separate zones etc? With some more information then we maybe able to suggest other alternatives. To be honest, if you really need 6 zones of amplification and be able to control them all separately then £1400 sounds like quite a good price already. Something like a Sonos system may be easier to use and setup but will probably cost a fair bit more although you could build the system up in stages by adding each zone/room as funds allow.
  3. adamroutley
    adamroutley
    Aug 13, 2013
    57
    11
    Wolverhampton
    +11
    Zone one - lounge, hall
    Zone two - kitchen, utility
    Zone three - garden
    Zone four - upstairs
    I think 6 would be slightly overkill but better to have more than not enough.
    I agree, it seems like a very good price. All inclusive unit without the need for separate amps. Just run Ethernet to the room controllers and speaker cable to the ceiling speakers
  4. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,439
    How many speakers do you envisage in each zone. Often these multichannel amps require a quite narrow impedance range which can make conencting more than 2 speakers to a zone difficult.
  5. adamroutley
    adamroutley
    Aug 13, 2013
    57
    11
    Wolverhampton
    +11
    With that in mind, probably 2 ceiling speakers in each zone. I have a separate surround sound that I use for movies which won't be connected to this.
